Upgrading motherboard help
Synckid
Hello tomshardware, i currently have a hp 8200n with a burnt mobo. Im looking to get an intel based mobo, but.. i dont know what type of case i have, atx, etcetc. Would you techies be so kind to assist me????
It is a micro-ATX motherboard and the case is a mini-tower. You could reuse the case for a simple basic PC. If you want a high performance PC you should get a bare PC case with better cooling.
ASUS H81M-K
http://www.newegg.com/Product/Product.aspx?Item=N82E16813132052
Intel Pentium G3258
http://www.newegg.com/Product/Product.aspx?Item=N82E16819117374&cm_re=g3258-_-19-117-374-_-Product
G.SKILL Sniper 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model F3-10666CL9D-8GBSR
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231417
ASUS H81M-K
Intel Pentium G3258
