Upgrading motherboard, need help and/or advice
jixan
Hi,
I bought an oem advent machine a while back, which has lasted me pretty well. The model number was t9509, spec list of that machine is here
http://www.uktsupport.co.uk/advent/pc/t9509.htm.
I mostly still have the same components as that list, except for an upgraded psu, to 500w I think, and a radeon 6850. Other than that, same parts.
Currently it does not run the games I want it to very well, I suspect it may be partly due to the 2gb of memory it has, but also that the 2.4ghz quad processor is a little slow. RAM I can get, but I understand the processor (q6600) is quite overclockable, and I was keen to give this a try. Mobo is locked though, so I think I need a new one. This hits the limits of my computer knowledge, not sure what would be a good upgrade, or what I need to look for. Would something like
http://www.dabs.com/products/asus-p5qpl-am--intel-g41--775--2ddr2--onboard-dsub--pci-ex16---6-chhd-sound--matx--gb-lan-64N2.html?refs=405070000&src=3
<--- this do me well?
Advice much appreciated.
jixan
Only just noticed this board is micro atx, ignore that. Any suggestions as to a good board to buy would be great.
jixan
Looking around and found Gigabyte SKT-775 G41MT-S2P, would this work well? Am I right in thinking this would work with all of my current components?
