thiduck :
Ok , i have INTEL DG31PR mother board and run core 2 duo. How can i overclock this(currently running at 2.6 GHz).
And also what is the difference b/n ddr, ddr2 and ddr3?
And one last thing - Will i see SIGNIFICANT change in speed if i change my ram from 2gb one to 4gb as much as i do if i change my CPU?
ty nerds
DDR, DDR2, DDR3 are successive generations of faster ram. They are incompatible, and this is enforced by different slot configurations.
It is a moot point since your motherboard will take only one type; DDR2.
Added ram will not make your cpu go significantly faster.
If you have only one stick, then adding a second may make a minor positive difference.
A more important reason to go to 4gb is to be able to keep more code in ram and avoid page faults to the hard drive.
I would recommend it.
If you will add ram, be aware that
Ram is sold in kits for a reason.
Ram from the same vendor and part number can be made up of differing manufacturing components over time.
Some motherboards can be very sensitive to this.
Although, I think the problem has lessened with the newer Intel chipsets. Still,
it is safer to get what you need in one 4gb kit.
You want documented ram compatibility. If you should ever have a problem, you want supported ram.
Otherwise, you risk a finger pointing battle between the ram and motherboard support sites, claiming "not my problem".
One place to check is your motherboards web site.
Look for the ram QVL list. For your motherboard, it is here:
http://www.intel.com/support/motherboards/desktop/dg31pr/sb/CS-027918.htm
It lists all of the ram kits that have been tested with that particular motherboard.
Sometimes the QVL list is not updated after the motherboard is released.
For more current info, go to a ram vendor's web site and access their ram selection configurator.
Enter your motherboard, and you will get a list of compatible ram kits.
While today's motherboards are more tolerant of different ram, it makes sense to buy ram that is known to work and is supported.
As to overclocking, that is possible, and you might see a performance boost if your app is cpu limited.
If your app is gaming, then a better graphics card is usually the more productive thing to do.
