I live in a single floor rented 2 bed flat in the UK.
Unfortunately, the telephone connection to the flat is in the bedrooms, so I have my 'EE Smart Hub' at one end of my flat and the majority of Wi-Fi devices are at the other end.
I have ethernet connected to my 'EE Smart Hub' to one of the TP-Link TL-PA7010PKIT wall plugs (I cant drill holes through walls to run cables as it is a rented flat), then the other TP-Link TL-PA7010PKIT wall plug is plugged into the lounge plug socket which then goes into an old Virgin router which is a Netgear WGR614 v9.
This works great for the wired stuff, TV, X-Box 1, Media PC, Raspberry pi (octopi), but we have issues with the Wi-Fi dropping out randomly (mostly works fine, but iPhone's seem to have issues and occasionally the eco dot's disconnect).
I have the Netgear WGR614 v9 setup as a 'slave' router, so the DHCP is being organised by the EE Smart Hub. Both have the same SSID and password.
I have bought an 8 Port network switch (Netgear GS108UK) which should be arriving in the next couple of days. I bought this to separate the wired stuff from the second router and give me more ports. It means that I can now turn off the router and turn it back on to re-set it and not affect the wired devices when there is an issue with the Wi-Fi.
I'm wondering if the issues are caused by the Netgear WGR614 v9 just being too old and needing replaced?
After a bit of research I've come across the Asus RT-AC66U B1 which looks like an ok router and not a bad price to be a new replacement for the Netgear WGR614 v9.
Just wondering if there is anything I could have done better with my current devices, or if there are other router options which might be better than the RT-AC66U B1 for around £100?
Thanks in advance for the responses!
