Upgrading my power supply. (Dimensions)
Minca2013
Commendable
Jun 24, 2016
7
Im not sure how power supply dimensions are measure so I came here to ask.
My current power supply is a SL350 350w psu:
http://www.tierratek.com/store/pc/viewPrd.asp?idproduct=4847
With the dimensions off: 140*150*68 (L*W*H)
The new one I would like to upgrade too is the CS650M:
http://www.corsair.com/en-ca/cs-series-modular-cs650m-650-watt-80-plus-gold-certified-psu
150mm x 86mm x 140mm
Im not sure how the second power supply dimensions are measured and I just want to be sure it will fit in my case. There is room above and in front of my current PSU so if those are the affected dimensions im fine, I think im ok but I just want to be sure.
Yes it will I checked the specs on amazon L*W*H did in to mm (the amazon measurements where in inches) and they were pretty much the same the corsair is kind of weird and has it like L*H*W
Thanks for your help, going to have to upgrade my PSU GPU and maybe even my motherboard depending on my new GPU. But thanks for helping me with problem one.
