G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
So, I recently bought a new computer from Dell for our small office. It
came pre-installed with Windows XP Home, which we wanted to upgrade to
XP Pro. I did what I thought was a clean install by deleting the
partition that the original OS was on and installing the XP Pro on a
new partition. However, now when I startup I am given an option between
using XP Pro and XP Home. Does this mean that they are actually
installed on the same partition? (Because I hear this is a bad thing.)
Or are they installed on two different partitions and I just have a
multiboot system? And if they are on two different partitions, how
would I delete the one with XP Home on it? Mind you, I know very little
about computers, so too much jargon will likely confuse me! Thanks for
any help!
teamchild
any help!
teamchild
