Upgrading parts($500)
nkhlgeorge
17
ok heres the deal, i plan to upgrade my computer with a budget of about Rs 25,000( thats about $500) i presently have a Pentium dual core processor 2.80 Ghz. and a 160 GB hardrive. the components i wanted to upgrade were-
motherboard, graphics card, PC case,teh RAM and the PSU( have to buy one)
The configuration i had decided upon was as follows-
Motherboard- Gigabyte EP43-DS3L, Intel P43
RAM- 2*2 GB Kingston DDR2 800 MHz
Graphics card- Zotac Geforce 9800GTX+ 512 MB
PC CAse- NZXT Alpha Black *3P*32
PSU- Cooler Master Extreme Power 500 W
i want to use the PC for gaming, and day to day uses such as word processing, movies internet etc.
will this motherboard support Pentium i7. and will these components work winth windows 7?coz i plan to soon upgrade.
thanx
ok, i7 is out of your price range, the only boards that support i7 ONLY support i7, heres what it would take for i7 (its going to be a lot more expensive since you need a new cpu as well for the i7)
the build is not bad, but i would get a corsair 550w instead (better build, though a little more expensive)
if a GTS250 is as expensive or cheaper get that instead of the 9800+ (same card, different name)
Griffolion
1,806
Switch your ram from Kingston to Corsair is my advice.
I7 is out of your range financially.
As hundredislands said, get a p45, much more stable for some serious overclocks on the cpu.
