[SOLVED] Upgrading parts, need your advice!!
Mar 30, 2019
Hi all. My gpu recently fried and been having issues in general with hardware just getting old. I'm looking to buy a GPU, CPU, and a motherboard for mid tier gaming, I guess. Don't need to run newest games on ultra but needs to have capability to at least play most games.
These are the parts I'm considering, everything left out I already have:
Radeon rx 570
Amd ryzen 5 2600
Asrock b450 pro4 atx am4
Please tell me if these parts work well together and if there's better options for better price. These are cheapest I could find on pcpartpicker but I'm not very tech savvy and would love a second opinion.
Thanks for your time!
If you're budget won't stretch to 16GB of RAM then 8 will be fine for now, you can always come back to it later, just make sure it is 3000Mhz or faster and get dual channel. The 2600 is a really good value CPU that should handle anything you throw at it. I wouldn't increase the RAM at the expense of the GPU, the RX570 is a solid mid range GPU and probably offers the best bang for your buck.
How much RAM do you have? I know a bunch of people who recently bought a RX570, but that's because it came with two games. Make sure you're getting the same deal!!! I think it's AMD who's offering it. If you're not let me know and I can send you a link.
One last thing, are you planning to overclock your PC eventually?
Yeah, the rx 570 I haven chosen comes with the 2 games.
I was planning on going to a local shop to get 8gb of the cheapest ram that's comptible and no, I doubt I'd ever overclock. Just want a pc that will run stable for a few years, doesn't need options for upgrading but some wiggle room would be nice.
What's your budget? Are you looking for fancy RGB? I would suggest getting at least 16GB for now and making your build future proof for at least two - three years.
Budget is 500 CAD, I have a case and psu that I recently bought and if recommended will get 16gb instead of 8gb.
Are the 3 parts I put together a good starting place for future proofing?
Get these instead of you selection:
ASUS Radeon RX 580 4GIG
ASRock Fatal1ty B450 Gaming
AMD AM4 Ryzen 1700x 8 cores 16 threads 3.2
That goes way over her $500 budget... LOL
I would go with the AORUS Pro if your budget allows you, since I just did a build myself, I have a feeling that will just be a tad over your budget, but will be worth it.
Also, if you don't need all the cores, you don't do any type of design work / work which you requires heavy core work, you don't need the 1700X...The 2600 is fine if you're looking for gaming / productivity.
Same here that's why I'm buying so many parts at once. I'm set on the ryzen 5 2600 and Radeon rx 570, which of the recommended boards is best? I can prob swing $600 total if I eat noodles and rice for a month lol
