Approximate Purchase Date: ASAP
Budget Range: 700-800 €
System Usage from Most to Least Important: Almost everything you can use a pc for. Stability and longevity more important than high end performance though
Are you buying a monitor: No
Parts to Upgrade: (e.g.: CPU, mobo, RAM, SSD)
Parts Preferences: by brand or type (intel cpu non negotiable, gigabyte mobo gskill ram, negotiable)
Overclocking: No
SLI or Crossfire: No
Your Monitor Resolution: 1280x1024 until I get a new one, in the future
Additional Comments: I do play games but mostly turn based ones. I need this pc to be in good condition for quite a while, I will not be buying a new one for at least 7-8 years.
And Most Importantly, Why Are You Upgrading: (well my pc is almost 8 years old 😛)
Quick link to parts (ignore vendors, I don't want to order parts from another country, I live in Greece)
http://pcpartpicker.com/p/Vv7QXL
Breakdown:
CPU:
Intel Core i5-6500 3.2GHz Quad-Core Processor
http://ark.intel.com/products/88184/Intel-Core-i5-6500-Processor-6M-Cache-up-to-3_60-GHz?wapkw=i5-6500+3.2
Mobo:
Gigabyte GA-Z170X-UD3 ATX LGA1151 Motherboard
http://www.gigabyte.com/products/product-page.aspx?pid=5499#ov
But also thinking: GA-Z170X-Gaming 5
http://www.gigabyte.com/products/product-page.aspx?pid=5498#ov
UD3 is cheaper by around 35 € in my parts.
RAM
G.Skill Ripjaws 4 series 16GB (2 x 8GB) DDR4-2400 Memory
http://www.gskill.com/en/product/f4-2400c15d-16grr
(it is virtually identical to ripjaws V but cheaper (at least here)
I really need a minimum of 2x8 GB, would like 4x8 but above my budget.
SSD
Samsung 850 EVO 500GB M.2-2280 Solid State Drive
http://www.samsung.com/us/business/computing/solid-state-drives/MZ-N5E500BW
Need a minimum of 500 GB. Will be a system drive (win 7 probably, possibly win 10 if a gun is held to my head)
I have a Corsair hx 650w PSU I will be keeping
http://www.corsair.com/en-us/hx-series-hx650-power-supply-650-watt-80-plus-gold-certified-modular-psu
And a sapphire HD 6790 which I might replace in the future, not anytime soon though.
Good Lian Li case with plenty of room.
A particular quirk I have is that I tend to have a lot of HDDs inside. Currently I have around 6 sata hdds, one of which will be replaced by the ssd.
Any comments on the build? Any thoughts of a part that is overkill due to limitations by other parts?
Overclocking: No
Breakdown:
CPU:
Mobo:
RAM
SSD
