G
Guest
Guest
Archived from groups: alt.sys.pc-clone.dell (More info?)
I bought a refurbished Dell Dimension 4550 about a year ago. Current
specs (after some upgrades) are: P4 2.5 Ghz,DVD-ROM, DVD-RW, 60 GB HD,
Verto GeForce FX5700 128 MB Ultra (has its own fan and draws power
from the PS directly, not only via AGP slot) and ATI TV card.
I plan to add a second hard drive and a sound card in the future. I am
worried that the power supply (rated at 250W per Dell manual) is not
enough. SO I went and bought a 350W Antec power supply.
My 2 questions are:
1) Do I need a bigger powersupply? my main worry is when I am burning
a DVD that the Dell PS may not supply enough juice
2)Is a standard ATX power supply compatible with Dimension 4550 or do
I need to look for some other specs?
Thanks. Please reply to newsgroup.
Tony
My 2 questions are:
Tony
