Upgrading to Skylake, need some help with Mobo and RAM
SteffanDavies
43
I'm ditching my old Q6600 and upgrading to i5-6600K. Looking for cheap but decent Z motherboard and DDR4 RAM because I'm on a tight budget (500-600€ including CPU)
Approximate Purchase Date: Next month
Budget Range: 500€ +-
System Usage from Most to Least Important: Gaming
Are you buying a monitor: No
Parts to Upgrade: CPU, Mobo, RAM
Do you need to buy OS: No
Preferred Website(s) for Parts: None, I may actually get the parts from local store, but online isn't out of the question
Parts Preferences: None
Overclocking: Yes
SLI or Crossfire: No
Monitor Resolution: 1920x1080
- A Z motherboard for overclocking a 6600K on air. Don't need SLI/Crossfire as I'm only using 1 GPU (R7 260x).
- DDR 4 RAM, leaning towards 16GB (I don't think 8GB is futureproof)
PC mostly used for gaming. As far as I know, RAM speed doesn't have a substantial effect on performance, does this mean I should be looking at cheaper 2400Mhz RAM Kits? Is it worth overclocking RAM at all?
Here is my suggestion. The RAM sweet spot for Skylake seems to be in the 2666-3200 range. If you are going to overclock you will want some headroom to accomodate so I would look for some 3000 so you can work up to that point. Having said this, the difference is not huge. I would buy 8GB of higher ram than 16GB of lower ram. Current games rarely require more than 8GB of ram and I don't see that changing in the foreseeable future.
I posted the local websites I used for pricing below the build information.
PCPartPicker part list: http://es.pcpartpicker.com/p/mkwtjX
Price breakdown by merchant: http://es.pcpartpicker.com/p/mkwtjX/by_merchant/
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor (€285.00)
CPU Cooler: Zalman CNPS10X Performa CPU Cooler (€33.95)
Motherboard: Gigabyte GA-Z170-HD3 ATX LGA1151 Motherboard (€119.90)
Memory: G.Skill Ripjaws 4 Series 8GB (2 x 4GB) DDR4-3000 Memory (€79.00)
Total: €517.85
Generated by PCPartPicker 2016-02-09 19:51 CET+0100
http://www.microcaos.pt/componentes-processadores-socket-1151/10549-cpu-intel-core-i5-6600k-35-ghz-6mb-cache-lga-1151-1010546.html
https://translate.google.ca/translate?hl=en&sl=pt&u=http://www.kuantokusta.pt/informatica/Componentes/Motherboards/Gigabyte-Z170-HD3-p-1-438252&prev=search
http://www.f13pc.pt/loja/detalhes.php?id=7648
http://www.f13pc.pt/loja/detalhes.php?id=3950
http://www.gskill.com/en/wheretobuy/list/pt
Hi and thanks for the response! As I had no answers since I posted I decided to go with an AsRock Z170 Pro4 (10 phase for OC) at around 125€ and 2x8GB Gskill Ripjaws 2400 for 88€. Should last me a while.
