TLDR: If I plug this RGB hub’s “CPU_Fan” connector into a “SYS_Fan” header, will something get fried and end in disaster?
I bought a three-pack of aRGB fans from UpHere that come with a hub.
The manual is kind of unclear and says that the hub needs to be plugged into CPU_Fan “only”. But I already have an AIO plugged into that header.
The manual says that the “Fan 1” on the hub can detect the PWM fan speed of the PWM fan. However my AIO has two fans going into a splitter.
Would I need to plug the hub into CPU_Fan if I only intended to use it for the three case fans? Would the hub have any problems being used with the splitter?
System:
AMD Ryzen 5 5600x
MSI B550 Tomahawk
CoolerMaster ML240L v2
System:
AMD Ryzen 5 5600x
MSI B550 Tomahawk
