So, for the past couple months, my upload has fluctuated at night on SOME nights. However, in the past couple weeks, it happens EVERY. SINGLE. NIGHT! I can almost set my alarm to it! It always starts between 6:55 - 7:55, and lasts for about an hour. At first, I thought it was just a virus/issue with my computer. BUT, it occurs with EVERY device in the house, via wifi AND wired.
Things I have tried, before you ask:
Connecting straight into modem
Unpluggin/plugging in COAX cable
Reset modem
Test via wifi
Test wired
Test over MULTIPLE devices
Technician came out and fixed issues, but not the one I called for (mainly wiring issues and laziness from past installers)
Contact CS (no help)
As a Twitch streamer, it makes this 10x worse, and that hour is HUGE for me... Idk what to do at this point! I feel as if I have tried it all. ALSO, I use the modem/router provided by Charter.
Speedtests when issue occurs:
1st Test: https://ton.twitter.com/i/ton/data/dm/994729982529343493/994729972655849472/dr6zFvEY.jpg:large
2nd Test: https://ton.twitter.com/i/ton/data/dm/994730272758419460/994730266026561536/QbVJIsqz.jpg:large
3rd Test: https://ton.twitter.com/i/ton/data/dm/994730489197092873/994730481349529600/63aBBx47.jpg:large
Reset modem
Test via wifi
Test wired
