I'm not sure if this is the right topic, but I was about to get a UPS that can only take in circular pins. Issue is, my PC and dual monitors are square pinned. Can I use a normal adapter to solve this or do I have to get another UPS?
Hi
As long as the adaptors will take the load then they should be ok.
If you are getting it from a different country though,make sure that the UPS voltage matches your voltage.
Hi
