UPS Internal Temperature
MarkBitterman
Hey there, I'd like to ask for some opinions on this.
I recently bought my first UPS, and I notice that while the plastic casing has a normal temperature, the screws on the bottom that tether the internals are much higher in temperature.
Is the elevated internal temperature normal for a UPS, or do I need to be concerned? Because otherwise it seems to work perfectly fine, I'm just paranoid about having my house burn down one day.
This is the unit I got:
http://www.ewent-online.com/index.php?language=en&page=product&productid=1414
Thanks.
Usually UPS's internal temperature is higher as compared to external temperature. So, I think you need not to worry. But, be sure that it is abnormal heat up or any abnormal problem in your UPS.
