UPS making noise?
malm11
I'm getting conflicting answers -
I bought an apc smc1500 to protect my pc components.
But when I plugged my new APC, it makes a fairly loud buzzing noise when it's *not* under battery load and *not* connected to anything aside from being plugged in.
I can't find a solid answer online. To me, the constant buzzing doesn't seem normal.
What are your experiences with UPS devices?
Yes, when I disconnect it and it runs on the battery, it makes a fan running noise which sounds normal to me.
But when the battery is fully charged and there's zero load, the unit makes a constant buzzing noise.
