UPS Power unstable
Chito Serrano
41
Hi we have unstable power here at home especially when our Refrigerator is on.
I am Planning to buy a UPS the model is APC BR500CI-AS 500VA ups
Question: Can this model support my computer so it can't be interrupted?
my specs is
A8 6600K
Sapphire Vapor X 280X
Cooler Master Silent Pro M 1000
8GB Ram
GIGABYTE GA-F2A58M-DS2 FM2+
2 2TB HDD
Please advice, Thank you very muCH :)
A 500VA UPS would be at the limit (if not overloaded). I would recommend a 1000VA UPS. If you have voltage drops, a UPS may or may not protect you. Some are better than others. Your power supply is rated down to 90VAC. If your power is dropping that low, your UPS should kick on.
@Kanewolf...Thanks for the response. I see, also I'll be adding a sony 43x800c LED on that set up. how about this FSP FP 800 (800VA/300W) Line-Interactive?
Its branded and it suits my budget.
Product Description
Model FP 800
Capacity 800 VA / 480W
Input/ Voltage 110/120 VAC or 220/230/240 VAC
Input/ Voltage Range 81-145 VAC / 162-290 VAC
Input/ Frequence 60/50 Hz (auto sensing)
Output/ Voltage ±10%
Output/ Frequence Range 60 Hz or 50 Hz ±1 Hz
Output/ Transfer Time(Typical) Typical 2-6 ms,
Output/ Waveform(Batt. Mode) Simulated Sine Wave
Battery/ Battery Type & Number 12 V/ 9 AH x 1
Battery/ Typical Recharge Time 4-6 hours recover to 90% capacity
Physical/ Dimension, (mm) 279 x 101 x 142
Physical/ Net Weight (kgs) 4.9
Hi Guys me again.
SO I bought this INTEX 1050VA and plugged my CPU and LCD/tv Monitor.
A8 6600K
8GB Ram
2 2TB HDD
Samsung 32" Series 5 LCD
Charged it for 12 hours.
Plugged both. I tried to pull the plug of UPS from the outlet to see if it can handle the CPU and Monitor. Great! it can
Problem is, the monitor still turns to Black whenever the Fridge turns on and off.
Please help? what's happening...Thanks again and belated merry Christmas
