This isn't exactly an easy or quick answer. The answer requires a lot of decisions to be made.
The first choice is the type you want. There are 3 different types of UPS units to decide on. Standby, line interactive, and online UPS units. The prices of these go from standby being the least and more basic to the online being the best and most expensive by far. You have to decide on what one of those you need/want. After that, you need to look at what type of wave your power supply can take. Different UPS units have different output wave formats you need to consider, or you might end up destroying your system with the unit you bought to protect it with. After you've found the first 2 you can calculate the amount of power you want to support and the amount of time you need it to stay online after the power goes out.
How much are you looking to spend how long are you wanting it to provide backup for?
