Pretty much what the title says. My upstream power levels seem to be lower than the minimum spec for my modem wants and I would like some advice on how to fix it without having to bring in a tech. I still receive internet and connectivity, but the low power causes my connections to fluctuate a lot.
My modem is the Motorola Surfboard SB6183 http://arris.force.com/consumers/articles/General_FAQs/SB6183-Cable-Signal-Levels
It says that it requires a minimum of a 45dBmV power level, but my channels range from 32.4 to 35dBmV. All of my downstream power levels seem to be in a good zone between 5dBmV to 6dBmV, and they have wiggle room to be decreased to help the upstream.
I was thinking of adding an attenuator of some sort to help increase the upstream power level, but adding the amount I need would then decrease the downstream quite a bit (still in the spec of +/- 15dBmV, but still a large amount).
I just wanted advice as to how to go about this problem. I need to increase my upstream by about 13dBmV, but keep the downstream within the +/- 15dBmV range. Any ideas?
https://imgur.com/a/0yDUt
