URGENT ADVICE required on high spec PC for Adobe Design
mkhaliq
58
I require a high spec Design PC to use the Adobe suite of software mainly PS and AE. I have listed a combination of specs below given the budget of around $1200 (excl. monitor). I have read many threads and i'm really afraid of possible bottlenecking with my listed specs below. Also the GPU must be able to use the latest features of Photoshop CC.
I require advise on the best setup from experienced PC builders!
Spec 1:
i7 4770K
Asus x79
32GB RAM (pls advise compatable brand and spec)
Geforce GTX 760 2GB (or is 4GB required - major benefits?)
Spec 2:
i7 4770K
Asus x79
16GB RAM (pls advise compatable brand and spec)
Geforce GTX 780 2GB
Spec 3:
i7 4930k
Asus ?
Geforce GTX 770 2GB
You can see in eachof the above where i am sacrifices something i.e RAM.
Please advise.
Extra 2GiB might be worth it, not sure. Is what you're doing going to use CUDA? Some parts of CS are CUDA-only, some have OpenCL support too.
Most of the Adobe stuff likes more threads, so the six core 4930K is a good idea. I'd be looking at Spec 3:
CPU: Intel Core i7-4930K 3.4GHz 6-Core Processor ($568.99 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($29.99 @ NCIX US)
Motherboard: MSI X79A-GD45 Plus ATX LGA2011 Motherboard ($224.99 @ Newegg)
Memory: G.Skill Ares Series 16GB (4 x 4GB) DDR3-1600 Memory ($153.99 @ Newegg)
Video...
Budget is Around $1200. You know best regarding the Motherboard, what ever it takes to run either CPU's.
So do you agree with GTX 760 not being ideal with i7 4770K?
Also, will extra 2GB RAM make major difference on GPU?
Video Card: Zotac GeForce GTX 760 4GB Video Card ($257.99 @ SuperBiiz)
Total: $1235.95
(Generated by PCPartPicker 2014-03-15 11:09 EDT-0400)
LGA2011 tends to be pricey, though.
Off to bed now.
