Urgent! Can 6 pin plug in to 8 pin card?
Jayce Lou
15
Need help urgent! I've just bought a Gigabyte GTX 950 XTREME Gaming and realize that my 450W PSU only have a 6 pin plug but the card require 8 pin. Will it still OK to plug in 6 pin PSU to 8 pin card. Thanks.
While it will technically fit, I cant recommend using it as such.
The card requires the wattage from the PCIe lane plus the 8pin. If its designed for the 8, use 8.
Umm... I don't overclock and I don't game much. Giving the requirement for PSU just 350W and mine is a 450W, so, would it by sufficient wattage? BTW, what is the missing 2 pin does?
Understand. Appreciate and thanks for your help.
I've just upgraded from a HD4890 which used 2x6pin power leads to an XFX 7870 which has 1x6pin & 1x8pin and it WILL NOT display anything with a pin plugged in to the 8pin socket, despite an article I read on here which said that it might because the two missing pins are only ground pins. I realise you have a different card. Just wanted to help out where I can.
Thanks for your advice.
For my case it seem a bit odd, you see, Giagbyte officially "suggested" for 350W PSU but require 8 pin connector? I mean, does any 350W PSU has a 8 pin PCIe connector? I really don't understand.
I write to them:
Question: I just bought the card and realize that it needed 8 pin PCIe connector, which is out of my expectation and I guess many others do. Why not just the COMMON 6 pin? The website "suggested" PSU was 350W which I guess don't have one.
Reply:
Answer:
Dear Jayce Lou,
Thank you for your kindly mail and inquiry. According to the product specification, the suggested power requirement for this card is 350W (with one 8-pin external power connector). In other to have sufficient power for optimum performance, we suggest you to connect the 8-pin external power connector.
Regards,
GIGABYTE
