Hello! Thank you for looking over my problem.
Main Issue
When I turn on my pc, the fans start up fast, then die down to about half speed and eventually shut off along with the entire system. There are no beeps or any display.
My System
Merc Alpha case
Gigabyte f2a55m hd2
AMD a4 5300
WD 500 GB HDD
x2 4GB G Skill Ripjaw RAM
Antec 450W PSU
What I have tried:
Overlooked and tested various tips on the thread concerning boot up issues found on these forums
Another PSU
Another Motherboard
Single stick of ram/ no ram
Resetting cmos/taking battery out for a period of time
What Happened
This is my first pc that I am building myself so I knew ahead of time I would not have all the answers should i run into an issue. However, I am now in desperate need of help.
I built my pc ok, installed windows, drivers etc. Once I tried to insert audio into the audio port in the back, the entire machine shut off. I panicked, opened the case, and saw that the HD-AUDIO port on the motherboard was only halfway inserted (4 pins/8pins)... Big mistake, I know.
I fixed it, inserted the psu back into the wall, noticing a spark in the outlet. Thinking nothing of it, i put it back into the back of my tower and started it up. I heard a pop and immediately shut off the system to prevent further damage. All seemed fine, but i could smell something burning on the motherboard. Tried starting it up once more but now it only start once with the power button; needing the psu to be shut off manually to turn it off or on. The fans (apu, psu) start up full speed for a couple seconds, but then die down to half speed. The system hangs for a minute or so and then completely shuts itself off.
I suspected the culprit to be psu but when i replaced it with a 625W, the same problem occurs. Today, I bought the same motherboard but the problem STILL persists. I will note that when I tried to start the psu manually with a screwdriver on the new motherboard, I accidentally tapped 2 usb prongs and saw a quick spark.
I'm totally lost and only got to use the damn thing for 5 minutes at most. The only other thing it could be is my apu/cpu. It is definitely secured and appears to be in perfect condition, lacking some thermal paste from the entire process. Please, any insight would be greatly appreciated. Thanks a lot!
Main Issue
My System
Merc Alpha case
Gigabyte f2a55m hd2
AMD a4 5300
WD 500 GB HDD
Antec 450W PSU
What I have tried:
Another PSU
Another Motherboard
What Happened
