Question "Urgent" Friend having connection problems when in friends lobby (IPv6?)
Camden.H
30
Ok, hopefully someone can respond to this in the next hour or 2 but my friend recently got a pc and i don't know all the specs but its the starter pro for NZXT and the pc works properly when hes alone but recently for the first times he has played with friends (3 total including him) he can join and everything works until a min or 2 after he joins the party, he disconnects and it doesn't matter who's host or anything that we have tried, at first on bo3 (we were playing modded zombies) he couldn't join at all because his NAT type was on strict instead of moderate or open and it says cant join because of NAT type when we tried joining him and just party is unavailable when he joined us, but eventually with the small-moderate amount of knowledge i have i got the NAT fixed and we have been able to join each other without any "failed" attempts but still it kicks him shortly after, we have tried different games and its the same thing he joins then gets kicked shortly after.
We have tried:
1:Reset internet/router
2:disable IPv6 (because that's the only thing that says No network access in control panel)
3.pretty sure we tried anything in cmd prompt at least trying to reset IPv6 unless we didn't reset it right
4.tried to update LAN driver though motherboard website (ASUS) but i don't think he got driver for windows 11 because he said that the file wasn't compatible with operating system.
So now we are stuck and he left for dinner and will be back in a couple hours so i hope i can get a response or something before he gets back if possible, thanks for any help you can provide
Ralston18
Look in Reliability History and Event Viewer. Either tool or both may be capturing some error code, warning, or even an informational event that precedes or corresponds with being "kicked".
Reliability History is much more user friendly. Event Viewer requires more time and effort to navigate and understand.
http://www.tomshardware.com/faq/id-3128616/windows-event-viewer.html
Make and model information for modem, router, or modem/router if combined. The router's logs (if available and enabled) may provide some clue.
Also: the PC. Doublecheck to ensure that only one network adapter (either wired or wireless as is being used) is enabled.
Last, if necessary: Run "ipconfig /all" (without quotes) on his pc via the Command Prompt. Post the results.
He should be able to copy and paste the results with no need to retrype everything.
Camden.H
30
He should be able to copy and paste the results with no need to retype everything.
Okay so my friend showed me that in reliability monitor there was errors there was red X's Yellow cautions, and in every line sense he got the pc a blue circle. The critical events were in Xbox game bar the Warnings were in the Epic games launcher, and the informational events were in Epic Online services, Epic Games Launcher, Epic Games Launcher Prerequisite, Security Intelligence Update for M..., and some Microsoft Visual C++ and then also he did the "ipconfig/all" and he tried to copy and past it to send to me but it was like a link thing that took me to documents, but it was there in the documents so idk if it'll work her e but ill try
and idk how else to do it but past the whole thing 😭, he didn't end up doing the event viewer but if u need it im sure he could get it :)
Windows IP Configuration
Host Name . . . . . . . . . . . . : Rambo
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : lan
Unknown adapter ProtonVPN TUN:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : ProtonVPN Tunnel
Physical Address. . . . . . . . . :
DHCP Enabled. . . . . . . . . . . : No
Autoconfiguration Enabled . . . . : Yes
Ethernet adapter Ethernet:
Connection-specific DNS Suffix . : lan
Description . . . . . . . . . . . : Realtek PCIe GbE Family Controller
Physical Address. . . . . . . . . : D8-5E-D3-E7-20-85
DHCP Enabled. . . . . . . . . . . : Yes
IPv6 Address. . . . . . . . . . . : 2607:fb90:d72f:8c18::2a3(Preferred)
Lease Obtained. . . . . . . . . . : Sunday, January 1, 2023 12:54:04 AM
Lease Expires . . . . . . . . . . : Wednesday, February 7, 2159 7:26:29 AM
IPv6 Address. . . . . . . . . . . : 2607:fb90:d72f:8c18:c49f:fb17:2dfe:c83e(Preferred)
IPv6 Address. . . . . . . . . . . : fd84:3a2b:9bbd::2a3(Preferred)
IPv6 Address. . . . . . . . . . . : fd84:3a2b:9bbd:0:684b:347d:4177:fe6b(Preferred)
Temporary IPv6 Address. . . . . . : 2607:fb90:d72f:8c18:99a1:204e:cff8:cb3b(Preferred)
Temporary IPv6 Address. . . . . . : fd84:3a2b:9bbd:0:99a1:204e:cff8:cb3b(Preferred)
Link-local IPv6 Address . . . . . : fe80::ae9f:b317:6b23:5295%10(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.12.239(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Sunday, January 1, 2023 12:50:52 AM
Lease Expires . . . . . . . . . . : Monday, January 2, 2023 12:54:03 AM
Default Gateway . . . . . . . . . : fe80::3e58:5dff:fe66:dc11%10
192.168.12.1
DHCP Server . . . . . . . . . . . : 192.168.12.1
DHCPv6 IAID . . . . . . . . . . . : 131620563
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-2B-34-F8-57-D8-5E-D3-E7-20-85
DNS Servers . . . . . . . . . . . : fd84:3a2b:9bbd::1
192.168.12.1
NetBIOS over Tcpip. . . . . . . . : Enabled
Unknown adapter Local Area Connection:
Description . . . . . . . . . . . : TAP-ProtonVPN Windows Adapter V9
Physical Address. . . . . . . . . : 00-FF-10-60-B7-E6
Wireless LAN adapter Wi-Fi:
Description . . . . . . . . . . . : Realtek 8821CE Wireless LAN 802.11ac PCI-E NIC
Physical Address. . . . . . . . . : B4-8C-9D-09-DB-E5
Wireless LAN adapter Local Area Connection* 1:
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter
Wireless LAN adapter Local Area Connection* 2:
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #2
Physical Address. . . . . . . . . : F6-8C-9D-09-DB-E5
Ethernet adapter Bluetooth Network Connection:
Description . . . . . . . . . . . : Bluetooth Device (Personal Area Network)
Physical Address. . . . . . . . . : B4-8C-9D-09-DB-E4
C:\Users\darre>Microsoft Windows [Version 10.0.22621.963]
... (339 lines left)
Ralston18
In Reliability History, take a couple of screenshots of representative days having multiple errors.
Post the screenshots here using imgur (www.imgur.com).
Start by uninstalling all of the Epic games software to determine if connectivity can be restored thereafter. Other games and related apps/utilities may need to be uninstalled as well.
Do be sure that he has backed up all important data to at least 2 x other locations and verified that the backups are recoverable and readable.
As for the "ipconfig /all" results I would uninstall the network adapter drivers and do a reinstall and reconfigure the network adapter as applicable to the host network. Ensure that only one network adapter is enabled.
Also run "sfc /scannow" and "dism" to clean up buggy or corrupted files.
Reference:
https://www.lifewire.com/how-to-use-sfc-scannow-to-repair-windows-system-files-2626161
How to use DISM command tool to repair Windows 10 image | Windows Central
Just as a matter of elimination.
Objective being to get back to a stable (no errors etc.) PC that has reliable and steady network/internet connectivity.
Then address the gaming apps etc..
Camden.H
30
View: https://imgur.com/a/BEwhhvB
Idk if I did that right but that link is the images and he isn’t sure how to download drivers correctly and or where a credible site to do it is… he said in some driver detector apps there’s a decent amount of drivers that say they need updated like 15-30
And also we have tested it in multiple games and its weird because we always are talking in discord but he never lags out of discord or anything other than games, we even tried ROBLOX... and he lagged out of that though on most golf it maps which is a game where u just play different courses of mini golf he could play, but if it was a bigger or there was just more in it it would kick him so im just full on confused at this point. ALSO he did get his IPv6 to say Internet when before it was saying "No Network Access" and i thought that was the problem but apperantly moving his router into his room and plugging straight into the router fixed that even though he was using ethernet before.
Ralston18
Epic Game Launcher installs failed. Not sure about the sequence of events....
Appears to have happened prior to the Xbox related critical errors.
Instead of camera photos use screen capture/print to get the screen images. Post those images via imgur.
Expand the Reliability History screen so all can be seen before the screen captures.
Informational events are important as well.
Also include a screenshot of "Review problem reports".
Camden.H
30
okay i have to work but I’ll try and get those asap
Camden.H
30
Well sorry for the no response but he ended up getting with the people he got it from and is just getting a replacement one 😔
