Urgent help for buying a GPU...
Dharshak
43
Hey guys I'm buying an used GTX 760 for $60.. I currently have a shit zebronics PSU which says 450w.. I just want to test the card before buying it... Can I test it using this power supply?
you can try, no predicting what would happen though
maybe it just wont turn on, maybe it will blow, maybe it crashes when you try to run something or put any kind of load on it
zebronics is that bad, maybe it pops and takes the whole system with it
no telling
no, that zebronics will probably blow up if you tried to get 450w out of it
no telling
