Hi! I was looking for some extra performance since my system is an older one, so i used the alienware profiles that they set for you. I used it once and it didn't work (clocks were still at 3.4Ghz according to cpu-z) so i tried again. I saved and exited and got greeted by a 'windows has failed to boot, probably because of a recent hardware or software change. heat is not a problem as it is extremely cold where i live thus very cold cpu and gpu temps (25 degrees celcius), and fan speeds are very high for gpu and main fans. I have tried safe mode, using last known working config, disconnecting power, and resetting bios (doesnt seem to apply, i select it, i confirm and press yes and i exit but still no luck. I looked in bios and according to it the cpu is at 3.4GHz. Please any help would be appreciated urgently.
Alienware Aurora R3 (with upgraded gpu, psu, and extra fan):
I7 2600k (3.4Ghz ._.
GTX 780 (1058) Overclocked by 100MHz
1000+ corsair psu (not sure how much watts by more than enough for sure
