Urgent help please
jtr1888
113
PC wont install windows
New build, i5 2500K + P8P67 mobo + HD6950 + 4GB RAM (authorized) + 128GB SSD
done a bench test, all ok.
Install SSD & DVD-Rom, vista installs 40% then hangs for well over an hour, mouse goes jittery then all freezes up
XP trys to install (well seems to) but then get instant BSOD
Dive is fine, formatted it, put in pc im on now without any other HDD, installed windows from same discs & booted perfect
What could I have done wrong in build if anything ?
On new build, SSD connected to white sata on mobo
Been tring since 8.30am, if any1 can help, would be gr8
Thanks
Def not ram, think Ive sussed it
Although I still cant install Vista, I have managaed to install XP (I think Vista disc has some added protection from Dell) anyway, what I did is change SATA from ACHI to IDE
Does it matter that I couldnt install from AHCI especially as mobo is brand new
Also, I "think" AHCI is for hot swapping, is this right, as this is a feature that I will use, well, possibly in the future
Thanks
