Hi Every 1, I am tagging on the post made by others, as I have a related query.. I do hope I get some advice and knowledge as well as pointers from you all..
I am not a Pro gamer, a semi-casual gamer who would like to play games on better fps. My current PC is a dinosaur (30fps).
The games I play are The Witcher 3: Wild Hunt, The elder scroll online, Used to play DOOM now Play Path of exile,
I need help with the following:
1) Is there any way I can better the build.
2) The stuff I have selected are making the build really Expensive.. I can afford it but would like to save some money for sure and may be turn down the dial. ( If you know what I mean) hehehe
3) Also I have never built a PC B4 so a little scared about it.. any tips on what to do and mostly what not to do would be helpful ( SHOULD I BUILD IT - Or - Should I just go and get it built by some 1 else)
My Current PC Specs:
- Processor: Intel(R) Core(TM) i3-3210 CPU @ 3.20GHz, 3200 Mhz, 2 Core(s), 4 Logical Processor(s)
- OS: Microsoft Windows 7 Ultimate
- GPU: NVIDIA GeForce GT 610 2GB
- MOBO : I do not remember and can not find out what it is .. ( I know Noob alert 😀 )
- RAM: 8gb
I am trying to make my 1st build and the specks that I have shortlisted are below:
- MOBO: ASUS ROG CROSSHAIR VII HERO Motherboard (Amd Socket AM4/Ryzen Series
CPU/Max 64GB DDR4-3600MHz
- CPU: AMD RYZEN 5 2600X 2nd Generation Hexa Core Processor - With Wraith Spire Cooling
Solution (AM4 Socket, 19m Cache, Up To 4.2 Ghz)
- GPU: ASUS GRAPHICS CARD PASCAL SERIES - GTX 1070 TI ADVANCED 8GB GDDR5 ROG
STRIX GAMING EDITION
- RAM: CORSAIR CMR16GX4M2C3000C16W Desktop Ram Vengeance Rgb Series – 16GB
(8GBx2) DDR4 Dram 3000MHz
- PSU: CORSAIR SMPS RM550X - 550 WATT 80 PLUS GOLD CERTIFICATION FULLY
MODULAR PSU
- COOLER: CORSAIR H100i V2 240mm Extreme Performance Cpu Liquid Cooler
- STORAGE: - SAMSUNG 860 EVO 250GB M.2 Internal Ssd - (MZ-N6E250BW)
- SEAGATE DESKTOP HARD DRIVE 2TB BARRACUDA (ST2000DM006)
- CASE: CORSAIR MID TOWER CABINET (E-ATX) - 300R WITH TRANSPARENT SIDE PANEL
(BLACK)
- KEYBOARD: COOLER MASTER MASTERKEYS PRO L Mechanical Gaming Keyboard Cherry
Mx Red Switches - With White Backlight
- MOUSE: RAZER BASILISK Ergonomic Wired Mechanical Gaming Mouse RZ01-02330100-R3A1
(16000 DPI, 5G Optical Sensor, RGB Chroma Lighting, 1000 Hz Ultrapolling)
- INTERNAL DISC PLAYER: ASUS 16X BLU-RAY Internal DVD Writer (BW-16D1HT PRO)
Any thoughts are greatly appreciated.
Cheers all
- RAM: 8gb
MODULAR PSU
(BLACK)
Cheers all
