(URGENT) Need help for a gaming build 800$ budget
Azn_souja
35
APPROXIMATE PURCHASE DATE: In a few days!
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: Gaming/Multimedia/Multitask
PARTS NOT REQUIRED: Keyboard, Mouse, Monitor
PREFERRED WEBSITE(S) FOR PARTS: http://www.ncix.com
COUNTRY OF ORIGIN: CANADA
PARTS PREFERENCES: i5 core if possible!
OVERCLOCKING: Maybe SLI OR CROSSFIRE: No
MONITOR RESOLUTION: 1280x1024
ADDITIONAL COMMENTS: Must have windows 7 and usb port in the front of the tower! As quiet as possible please, I would also like it to be able to run WoW on max graphics without FPS lag or anything like that.
This is really urgent, any help would be greatly appreciated! Thanks guys, I know this forum can help me!
fastx21
452
17
No offense but you're not getting a windows 7, core i5 750 and especially at canaidan prices for $800. For that price you're looking at a rana 440, 4 gb, 500 gb hd, a 5770, and some nice psu and case.
And if you really wanted to run wow only then above is exactly what you need. As quiet as possible? That' doesn't really exist in a gaming rig. You have the cpu fan, GPU fan, rear fan, psu fan, and a few more case fans.
Userremoved
1,276
14
Sorry you cant but you can go AMD tough:
(parts are from Best Direct (Canadian)
LG 16X DVD-ROM Optical Drive SATA Black OEM
In Stock
usually ships in 1-2 business days $15.16
Microsoft Windows 7 Home Premium Edition 64BIT DVD OEM
1 per customer. In Stock
usually ships in 1-2 business days $93.79
AMD Athlon II X4 630 Quad Core Processor Socket AM3 2.8GHZ 2MB Cache 95W Retail Box
usually ships in 1-2 business days $99.79
Antec Earthwatts 650W Power Supply ATX12V V2.2 EPS12V Active PFC 80PLUS 120MM Fan
In Stock
usually ships in 1-2 business days $82.73
Antec Three Hundred Mini Tower Gaming Case 300 ATX 3X5.25 6X3.5INT No PS Front USB & Audio
In Stock
usually ships in 1-2 business days $53.88
A-DATA Gaming Series AX3U1600GB2G9-2G 4GB 2X2GB DDR3-1600 CL9-9-9-24 Dual Channel Memory Kit
In Stock
usually ships in 1-2 business days $107.11
ASRock 890GX EXTREME3 AM3 DDR3 2PCI-E16 1PCI-E4 1PCI-E1 2PCI SATA3 USB3 Video 8CH Audio Mainboard
In Stock
usually ships in 1-2 business days $141.90
XFX Radeon HD 5770 850MHZ 1GB 4.8GHZ GDDR5 2XDVI HDMI Display Port DIRECTX11 PCI-E Video CARD-
In Stock
usually ships in 1-2 business days $173.32
Seagate Barracuda 7200.12 500GB SATA2 3.5IN 8.5MS 7200RPM 16MB Hard Drive OEM *3YR MFR Warranty*
In Stock
usually ships in 1-2 business days $55.38
Subtotal $823.06
Free shipping!
Userremoved
1,276
14
Unless you have like 200$+ for water cooling.
Azn_souja
35
Thanks, I don't know if this is a good build since I'm not good with these things but is there a way to make it just a slight cheaper? :) also is A-DATA good? How about G-SKILL
Oh and you're welcome ^^
Userremoved
1,276
14
Yes there is a way to cut back but your gonna have to wait for them to get these (1-2 weeks) these motherboards will arrive and have all the same features:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157191&cm_re=880_asrock-_-13-157-191-_-Product
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157198&Tpk=870%20asrock
They still support Xfire (8X/8X) but there are a few nerfs for the price but there minor (870 no integrated video-880 it's actually quite similar). G-Skill is another great company. you could also go down to a X3 (435) they perform great in games and they might have a fully functional 4th core but it that's not 100% that they will unlock and work.
Azn_souja
35
So maybe I'll just stick to the parts that you suggested, these are all fully compatible and they will work right? Sorry I don't know much about building computers xD
Userremoved
1,276
14
Yes they will but still those motherboards will probably cut like 20$ off that price. So I dont know it's your decision maybe NCIX will have them earlier and you could price match everything.
Azn_souja
35
Okay well I'm actually about to order the parts right now, it says available for pick-up at Richmond BC which is just a half an hour drive from where I live, do you think they'll put everything together? Or will I have to?
Anthony Brown
19
Go to ncix.com and go to buy a pc>gaming PC> then look through the 3 categories and the site lets you choose pieces for a fair price
sacara21
130
No one has posted on this thread for 3 years.... way to bring back dead threads talking about the i5 750 -.-
Similar threads
