*Urgent* power cables for gpu problem while building
Yep, both 6 pins (and like thomas said on a 6+2 pin just use the six).
As for your other question. The wires coming from the front ports/power should have a + or -, or a "pos" or "neg" (do your wires not have this?). Look in your motherboard manual to see which pin to connect them to.
you are good to go...your card needs 2 6-pin connectors. The one you are holding in your hand is a molex to 6 pin adaptor. Your psu should have at least one more 6 pin on it as well. You just plug both into the card. What psu do you have?
i have an antec hcg 620m. So i need to use both of the 6 pins? Does it matter where i connect them into my psu? It has 2 black ports for hdd and 4 more red ones for hdd/pci-e? Also this is off topic but how do i tell teh polarity of the hdd led, reset button, etc that plug into the motherboard from the front?
