Usb 2.0 Header HELP.
TeePoint
7
I Have a Maximus IX Formula MOBO. I have a Corsair 115i Cooler as well as the front panel 2.0 connectors that need to be connected to the 2.0 headers. I also have a NZXT usb hub.
I have the 2.0 connector from the nzxt hub plugged into the ROG_EXT 9 pin port right next to usb1314 slot http://cdn.overclock.net/e/e5/900x900px-LL-e537693c_IMG_4155.jpeg It says on the manual thats where the 2.0 connecters are. Its shared with the usb 1314 port.
The problem is, is my usb 2.0 front panels are not being detected in device manager or is my h115i being detected. The usb 2.0 panel ports do not work but the 3.0 ports do. Am i doing something wrong? This is my first build.
Also in the bios it shows 3 keyboards and 2 mouse detected. It also says the same under my device manager. Idk if that has something to do with it as well.
I have downloaded the drivers from asus. Also have updated my bios. The h115i is power cable is plugged into the cpu fan header. My front panel 2.0 panels do not work with a usb into it. My h115i does not detect at all in device manager.
Are you not reading my posts? I have everything plugged in. I have installed the corsair link software. Its not showing on there. and my usb front panel usbs dont work which are plugged into the nzxt 2.0 header. They are not showing in device manager. what do i do
