Hi to all. I've recently bought three new USB 2.0 hubs. The problem is that, when I connect each of them into a 2.0 port and plug a 2.0 pendrive in the hub, a message appears: "This device can perform faster if you connect it to a Hi-Speed USB 2.0 port." There's no message if I connect the pendrive directly to the port, without a hub.
If I click the message box, this window appears.
As you can see, the main internal hub is recognized as 2.0 ready (it is in bold), but my external hub (where my pendrive is plugged) is recognized as 1.0 as it is not in bold.
I proceed to make a benchmark with USB Flash Benchmark. Same port, same pendrive, same conditions. The results are depressing. 🙁
•Without hub = 8,8mb/s
•With hub = 0,84mb/s
Because of the lack of bandwith, devices that require 2.0 connections (such as a camera I have), do not work with the hub. It seems that I have been sold a 1.0 hub as a 2.0 one, but I make a last analysis with USBview.
The underlined lines show that the hub is 2.0 ready, so I'm confused.
It seems to be a problem related to the OS/drivers, but the drivers of my mobo are updated and I have tested the hubs in a W8.1 laptop with same results.
What can I do? Advanced thanks.
