Question USB 2.0 to USB 3.2 Gen 1 header adapter is required and a USB 3.2 gen 1 to USB 3.2 gen 2 adapter is required.
Jun 23, 2022
9
I have the Lian Li O11 Mini Case and wanted to pickup a budget motherboard which is the Gigabyte B660M DS3H DDR4 Micro ATX LGA1700. As the title is shown, PCpartpicker’s compatibility checker says I need those adapters. I do use PCVR but I’m not too sure if it affects the adapters, Can I find them on Amazon? Or do I not need them at all. Thanks.
https://www.newegg.com/p/1VJ-00R0-00025?Description=usb 2.0 to usb 3.2 header adapter&cm_re=usb_2.0 to usb 3.2 header adapter--1VJ-00R0-00025--Product&quicklink=true
I'm pretty sure it will be limited to usb 2.0 capabilities when used.
The other probably doesn't need an adapter...but you'll have to look at the header styles once you get the hardware to make sure.
