usb 2 and usb 3 port not working
allansusan2
137
:bounce::bounce::bounce::bounce: Hi The World I am running a Acer Laptop; I am using Windows 10. I have 1 usb 3 port that is working and 1 is not. I also have a usb 2 port that is also not working. I have gone into Device Manage and tried to update all the drivers; all to no avail. Then I went into find the driver for this laptop. When I have done all this; there was some resemblance of working only once or twice. After I have done all this it went back to having one usb port working and two not working. Does anyone have a remedy for this.
Allan
I went into Device Manager and worked on the USB Serial at the bottom. What I did was go to each one and dissable it; then I enabled it. Then it started to work but not 100%. If I am not mistaken my Laptop is a little under the weather. In other words Sick.
Take a look at the 2nd part of this link titled Disable USB selective suspend setting. See if changing the power settings on your machine might fix your problem.
http://www.thewindowsclub.com/usb-3-0-external-hard-drive-not-recognized
MERGED QUESTION
Question from allansusan2 : "USB Port Dead"
MERGED QUESTION
:bounce: All of my USB Ports work inconsistant with the exception of my USB Port thaat does not work at all; does anyone out there have any advice. I havae already tried everything in Device Manager; still it did not work. Can anyone help?
Allan
