I'm building my first computer and i was curious about the usb 3.0. my motherboard has a 19 pin header, but my case has a 20 pin connector. I was doing research for an adapter of some sort and came across headers that go into a pci slot. But when i looked at pictures it only had 19 pins even though it was advertised for 20 pins. There's no point because my motherboard has 19 pins. I did research and there isn't much that i found, but some people say you can plug 20 pin into 19 pin headers because the last one is a key pin or something like that. I'm looking for a solid explanation as to why the pci expansion cards are advertised as 20 but only have 19 and also if i can just plug the 20 pin connector into the 19 pin header.
Thanks
Thanks
