Long story short: I'm using an 'old' case that I like for a new build. However, a couple months ago cat knocked soda into the case. Case is completely clean and working fine aside from the USB 3.0 header which has some sticky residue in it. Would it be same to remove it from the case, dunk it in some rubbing alcohol, clean it and let it dry?
I'd love to use the USB 3.0 ports on the case, but I can live without them.
Thanks for any help.
