So i ordered a ASUS M5A97 LE R2.0 AM3+ AMD 970 SATA 6Gb/s USB 3.0 ATX AMD Motherboard. And looking at the pictures it doens't seem to have a usb 3.0 slot for the front panel conecetor. So what do i do now?
You have to go without it or buy an internal expansion card (for example: http://www.newegg.com/Product/Product.aspx?Item=N82E16815256001&cm_re=internal_usb_3.0_card-_-15-256-001-_-Product)
