USB 3.0 on motherboard wont work
elexthesinster
7
So i was using my PC like normally. Then i picked a mic that uses usb. For the first day it worked normally, until it just simply stopped working. the mic works if i plug into usb 2, but i use them for my mouse and keyboard. I checked the BIOS and everything and usb 3.0 is on. i have an AMD FX-6300
Motherboard;
MSI (Micro Star) 760GMA-P34 (FX)
UPDATE: the usb 3.0 on the case too do not work.
also i was able to fix it by disabling and enabling the usb 3.0 and it worked for a few hours and the it stopped working again like the first time.
so i tried to do the same and didn't work. need help.
no i cant find any for windows 10 but will it work if i download the win 7
Ok thanks I'll try it
Not sure, it should list all compatible Windows before downloading the driver. What you can do it try the USB port with a different thing like a Flash Drive. If it works, it's the headphones
I think so whenever they stop working I turn off the pc, turn off and turn back on the psu. I don't why but it seems to wrk at least for me
