So 2 of the pins of my USB 3.0 from the motherboard was bent and is cut off. Then it got stuck on the USB 3.0 Connector from a C.M Storm Scout cable of the front USB 3.0 port. It literally got lodged in the hole.
the pins that were cut off are 9 and 10.
I would like to have it removed. is there a way that i could split the connector in half to get it?
if i insert the usb 3.0 cable (with the pins lodged in) on a new motherboard would it caused a short circuit?
should i worry that the pins are stuck inside?
thank you for the answers.
