Hi all!
I've been noticing a problem with the USB 3.0 ports on my laptop. Whenever a 3.0 capable device is connected and is wiggled (even slightly) around in the port, the device temporarily loses connection with the laptop (more specifically a storage device). However, whenever I connect a 2.0 capable (storage) device (or force 2.0) and slightly wiggle it around, it is not affected.
I've verified that the connector for each of my 3.0 capable devices are fine and not the issue. I've also already tried cleaning the laptop ports with a cotton swab and a little isopropyl alcohol, and compressed air. I'm not sure if I didn't clean it well or it's a problem with the inside of the port...
I don't use my ports too often... How would I fix this properly? (I was about to try opening my laptop and pushing the contact metal inward a little, but I'm not sure if that will work very well.)
Thanks!
Thanks!
