USB 3.0 to SATA/IDE Adapter Drive Issue
Kylor Greene
4
Hey guys. I wasn't exactly sure how to title this post, so I'll go into detail.
I recently bought a USB 3.0 to SATA/IDE adapter as I have some old drives laying around and want to use them for storage.
I purchased: http://www.amazon.com/eFreesia%C2%AE-Converter-Activity-Support-EC-AHDD/dp/B00L1QH4T2
(As a side note, the above piece did not come with an AC adapter and I had to buy one separately. Well...I bought a cheaper yet similar item on clearance to use the AC adapter. I doubt that's relevant, but I'm adding it anyways.)
So, as my first project, I was give a hard drive from a family member's dying laptop to see if the files are salvageable (I believe they are). The drive is a 2.5" Seagate Momentus 5400.6 HDD. It uses SATA.
The drive powers on fine. The computer has recognized my adapter and correctly installed the drivers. However, it has attempted to install drivers for the drive as "USB Mass Storage Device" and has failed. I assume this means I need a different driver for the drive? But I'm not sure that is correct. I did not see any related drivers on Seagate's page.
I am unable to detect a new drive on My Computer and Disk Management only displays my system's drives.
So my question is what am I doing wrong and how do I fix it. Do I need a different set of drivers? Or is there another reason why the "USB Mass Storage Device" drivers fail?
EDIT: Forgot to mention I'm using Windows 7 64-Bit. My system does support USB 3.0 as well. Not sure what else would be relevant, but if more specs will help, I can provide.
EDIT 2: So, doing some more troubleshooting, I believe I have misidentified the issue.
As I said earlier I bought an older USB to IDE/SATA adapter because I needed the SATA power supply.
I figured, 'why not?' and decided to try to use it with the drive. Lo and behold, it works fine, I am able to read the drive.
So...I take it this means the issue is with my adapter. (Why not just use the working one? It's a USB 2.0. Push come to shove, I'll just be happy with it, but I have USB3 and want to use it lol).
This being said, any ideas?
Thank you for your help!
I'm not sure what is and is not remarkable.
When no drive is attached, the adapter shows up in 3 locations on the device manager.
Under Disc Drives as: Generic ATA/ATAPI Device USB Device
Under Portable Devices as: F:\ (but this F:\ does not show up in drive management...)
Under Universal Serial Bus controllers as: USB Mass Storage Device
Those are the ones I believe disappear when it disconnects.
It shows up as USB Mass Storage Device on Devices and Printers, and when I open it's properties those are listed under Hardware as well.
Once I attach a drive, the only thing that appears is the USB Mass Storage Device from above.
Does that make any sense or any help? Also, as I updated, I believe the issue is the bridge, not the drive...
These adapters are hit and miss, especially since the majority of "cheap" usb 3.0 devices were made when the standard was fairly new. It's not surprising. I bought three similar adapters back when, before getting one that actually works right. Try returning it first, buying another brand second. To my experience, this is another area where more expensive versions tend to be worthwhile while cheaper ones tend to be failures.
That makes sense. I can work with the USB 2.0 for a while. Is there any brand you would suggest?
