Hello Experts!
I've removed an external usb 3.0 2TB MYBOOK from its enclosure hoping to use it as an internal drive in my Mac Pro. Wrong! After reading various threads on the forum it appears that there's some sort of encryption at work that will render your drive useless. So i reconnected the drive to the original sata-usb bridge, hoping to recover the data, but no dice. The mac won't see it. Disk Utility doesn't see it. it doesn't show up in Volumes dir if i check via terminal. WD Disk Utilities detects there is a MyBook connected, but it can't find any volumes, so i cannot run any tests. Is there any way to get it working again? If not, is there a chance to recover the data?
I am running osx 10.6.8 on a 2009 Mac Pro ( old aluminum tower ).
Thank You in advance for any help.
Max
Max
