[SOLVED] USB 3.2 Gen 1 Header not compatible with case?
JunkSniperJoe
61
5
545
I've been using pcpartpicker to check for compatibility issues in my next build. When I look at the "potential issues/incompatibilities" list, I get this message:
"Corsair 5000D AIRFLOW ATX Mid Tower Case has a front panel USB 3.2 Gen 1 Type A port, but the Asus TUF GAMING X570-PRO (WI-FI) ATX AM4 Motherboard does not have sufficient USB 3.2 Gen 1 headers. The case USB 3.2 Gen 1 Type A port will not be usable."
To my understanding, the single USB 3.2 Gen 1 Type A header should support the two USB 3.2 Gen 1 Type A headers on the front I/O. I'm I mistaken, or is the site incorrect? Below is my planned build so far for reference:
PCPartPicker Part List: https://pcpartpicker.com/list/ZdBYz7
CPU: AMD Ryzen 5 5600X 3.7 GHz 6-Core Processor ($329.99 @ Adorama)
CPU Cooler: ARCTIC Liquid Freezer II 360 56.3 CFM Liquid CPU Cooler
Motherboard: Asus TUF GAMING X570-PRO (WI-FI) ATX AM4 Motherboard
Storage: Samsung 980 Pro 1 TB M.2-2280 NVME Solid State Drive ($199.99 @ Amazon)
Video Card: MSI GeForce RTX 3080 10 GB GAMING X TRIO Video Card
Case: Corsair 5000D AIRFLOW ATX Mid Tower Case ($162.57 @ Amazon)
Total: $692.55
Generated by PCPartPicker 2021-03-06 12:30 EST-0500
I've checked your board and PC case, and I agree with you...
Asus board has one USB3.2 header (for two Type-A ports) and one USB-C header (for USB-C port) for front panel -which fits perfectly with Corsair 5000D.
I think PartPicker warnings are "automated" and so maybe don't catch every detail perfectly.
