Motherboard: MSi B450 Tomahawk Max
CPU: AMD Ryzen 5 3600
Case: Cougar MX330-X
Whenever I plug something into the USB 3.0 port on the front panel, the entire computer freezes, including the boot screen and the BIOS configuration screen. When it is plugged in on boot, the motherboard gets stuck on the VGA debug light and only an underscore appears on the screen. (The CPU light also lights up momentarily, in case that's important). But when I unplug it, everything unfreezes. So if I press the power button, the computer turns off once I unplug the USB 3 device. The back ports don't have this issue.
Things I have tried:
- Updating the BIOS
- Using only one stick of each RAM
- Swapping the video card
