Question USB audio signal redirect
Apr 7, 2020
Hi,
I want to know if is there any way to send an USB audio signal from a regular headset to another device, like a console.
The exact result I'm trying to get is:
[Headset USB Out] -> [PC USB_1 In] -> [Software: Voice Changer] -> [PC USB_2 Out] -> [PS4 USB In]
Is there any way to get the USB signal and send that same data to the PS4?
I know it can be done with a 3.5" jack splitter and PS4 Remote Play, but the point of this is check if with this method it can reduce the delay (using Remote Play, there's some delay because of network speed)
Thank you!
