usb bluetooth dongle comes up as composite drive wins 7
bigj080808
19
don't know if i have posted this in the right place if not i apologise
i have tried running "systeminfo" so i could give some more perspective of what im running but that just closes as soon as its loads the relevant info
please help im goin insane
Cheers Glad i got it right
Its not got a yellow flag and im not sure what make it is its just a cheap 1 from ebay just a usb with a tiny black cover on back
Thanx for the help
Try connecting it to other usb ports and see if it shows something different.
ok i downloaded that and it didn't find any thing then i un-installed the driver and restarted my pc then moved the BT dongle to a different usb port and then the program found it patched a file but then could not contact the dongle and failed and it has now disappeared from that program
But when i go to devices it shows a
2.4GHz 2way RF Receiver but has it down as a keyboard/mouse category
Un-install it again, then run Bluetooth driver installer and see if that works
That can't be good...... well.... sorry, I am fresh out of ideas. I never came through that problem before. I even bought myself one very cheap Bluetooth USB and my computer automatically installed the drivers and it worked.
The only option I have for you is just to buy different bluetooth usb. It would be best to buy from a memorable manufacturer like Logitech, sony, asus and so on.
Once again sorry.
