Question USB-C front port but no header on mobo and no room for PCIe card
Dec 9, 2022
Hi, I'm building my son a PC for Xmas and think I've messed up on part selection after feeling very smug about some shrewd purchases. Wondering if I have any recourse. The case I bought is a NZXT H510 flow which has 1 USB 3.2 type A port and 1 USB 3.2 type C port. The motherboard I bought is an ASUS Prime B550M-A WIFI II.
Here's where I messed up, I read that the motherboard had a USB 3.2 header so I thought that would provide for both the type C and type A ports but it's a gen 1 port that is only supporting the type A cable from front panel and the cable for type C (cable is type-E?) has no matching port on the mobo. oops.
I googled and found that you can get a PCIe card which has an internal port for the USB-C type E cable I need but the graphics card is covering both the spare PCIe 3.0 x16 slots on the mobo. Much regret buying a mATX board instead of ATX...
I have one spare USB 2.0 header that is accessible on the motherboard, 4 USB 3.2 gen 1 (5 Gbps) ports on the back and 2 USB 3.2 gen 2 (10 Gbps) ports on the back.
Is there anything I can realistically do to make the USB-C port on the front work as expected? I really, really don't want to have to buy another mobo given the cost and effort required to replace it.
Dec 9, 2022
you can get this adapter to convert the usb 2.0 to usb c
so it will work at USB 2.0 speed? Any option to make the USB 3.2 header support both front ports or install some sort of hub?
D
Deleted member 2935556
Guest
i believe it will work a little slower speed but can still do everything
i couldnt find a splitter so that would be the best solution
