L laura_deschamp Distinguished Aug 1, 2003 7 0 18,510 Sep 8, 2003 #1 wen i download the driver for my printer everything works until it gets to the part about the usb cable connection,i know for a fact i have everything set up right but it says theres no connection..
M M39shadow Distinguished Apr 7, 2003 62 0 18,630 Sep 11, 2003 #2 What operating system and printer? It makes a difference. Make sure that your plugged into the USB ports on the PC. There may also be some problems with USB drivers for the motherboard. Some USB chipsets need a bit of help. Check for solutions at www.usbman.com
J jmecor Distinguished Jul 7, 2003 2,332 0 19,780 Sep 15, 2003 #3 make sure that the printer is turned on before installation. <font color=red>If your nose <b>RUNS</b>, and feet <b>SMELL</b>. Then you must be born <b>UPSIDE DOWN</b>.</font color=red>
J jmecor Distinguished Jul 7, 2003 2,332 0 19,780 Sep 15, 2003 #4 i don't think, this will be a problem with WINXP, it affects most 9x oses. <font color=red>If your nose <b>RUNS</b>, and feet <b>SMELL</b>. Then you must be born <b>UPSIDE DOWN</b>.</font color=red>
W WingDing Champion May 13, 2002 28,559 0 50,790 Sep 15, 2003 #5 If it's a USB 2.0 connection, then you'll need to have installed WinXP SP1 for it to work correctly. 😱 My CPU runs so hot it creates a quark-gluon plasma 😱
J jmecor Distinguished Jul 7, 2003 2,332 0 19,780 Sep 17, 2003 #6 or an updated USB driver for the mobo. <font color=red>If your nose <b>RUNS</b>, and feet <b>SMELL</b>. Then you must be born <b>UPSIDE DOWN</b>.</font color=red>
