G
Guest
Guest
Archived from groups: alt.comp.periphs.dcameras (More info?)
I've had an S3000 for about a year that I use on rare occasions (just don't
take that many pictures). I've never had a problem with it until now.
Right before Christmas I got it out and found that it had been put into its
case with camera turned on (and power save off). So the batteries had
obviously been run to zero. I installed new batteries, reset the time/date
and a couple of other trivial items and took some pictures without a hitch.
But when I connected the camera to my computer nothing happened. The
computer acted as if there were no USB devices connected and my camera did
not go into USB mode as it normally does when turned on while connected to a
USB port.
I have reinstalled the drivers, downloaded and installed new drivers, put in
brand new batteries, checked everything that I could find to check, etc.
without help. I am now convinced that it is either a camera problem or a
cable problem as I have connected the camera to two other computers (both
running XP), one with the correct Fuji drivers installed and one without the
Fuji drivers installed. In neither case would the camera go into USB mode or
did the other computers have any awareness of a USB connection having been
made.
At this point I don't know what to do but to start an "Easter egging
process" - probably first by replacing the camera's USB cable (which doesn't
appear to be a common one as far as I can tell). Can anyone think of
anything else to try before I start spending money.
Thanks.
dave (new guy here on alt.*.dcameras)
USB port.
made.
Thanks.
