Is it possible to reroute a rear USB 3.2 Gen 2 (10Gbps) cable from the header on the Asus B550-F motherboard to the front USB 3.1 Gen 2 Type-C (10Gbps) on the Fractal Design Define 7 Compact case. The front headers of that motherboard only offer USB speeds up to 5Gbps and there are two 10Gbps ports on the rear of the B550-F. I could buy the B550-E which does have the necessary front headers, but it is more expensive and I do not need the other stuff it has. The internal USB headers are also not sufficient but perhaps the rear ports are integral to the motherboard and cannot be rerouted?
