My brother's computer has been acting up with its USB 3.0 driver it appears.
Windows 10 keeps playing the device disconnect sound every three-ish seconds. The only ways the sound goes away is to disable USB Root Host (xHCI) in Device Manager, or plug a device into a specific USB 3.0 port on the back of his motherboard.
He is using a GIGABYTE GA-990FXA-UD5 R5 motherboard.
However, when the driver is uninstalled for the VIA USB 3.0 drivers, none of the USB 3.0 ports work, even with Microsoft's driver. In addition, one of the USB Root Hosts in Device Manager will then throw a Code 43.
When the VIA driver is installed and when Windows is making the sound, Device Manager keeps refreshing every time the sound is played. It seems like the computer thinks that a device is perpetually being disconnected. The device connected sound does NOT play unless I actually connect a device.
The driver for USB 3.0 is using the latest version downloaded directly from GIGABYTE's site (I believe it's 4.90). Windows is completely up to date. I have also performed a thorough virus scan with Bitdefender Total Security 2016.
Thanks!
Thanks!
